Different Caber rings?
Fruecrue
certified hand catcher
11:47 PM
Alden NY
Ordered 2 cross piston kits for the Caber rings because the deal was better than buying rings alone.
Obvious difference between the two sets.
Same supplier, same packaging, same part number.
What's the difference?
11:47 PM
TimRD
Makin' Little Ones Out of Big Ones
11:47 PM
Irwin, PA
That black coloring looks similar to what you'd see after heat treating steel to me. Weird that they have the same part number though. Did you try to clean the black coloring off to see if the Caber marking is there?
Fruecrue
11:47 PM
Alden NY
I have not.
5:47 AM
The few Caber rings I have/used were silver.
The black ones look as if they have been hardened?!
Nitehawk55
11:47 PM
Ontario
I don't think those dark ones are Caber , any I have got were light in color like OEM rings .
Even the end gaps are different in size and construction .
Maybe someone returned that set after doing a switcheroo ??
066 redeye
3:47 PM
Tasmania,Australia.
Just got non F cabers for my 066.They were gray.The place I got them from said gray non F,black F.They are gray because they are just cast iron.Black one's are more heat treated or chrome????
Cheers,Chris.
redtractor
11:47 PM
Maryland
Is "f cast" a process? A different material? Is this for longer life, better seal or easier break-in? What's the big selling point?
5:47 AM
If I got it right F-Cast are harder rings, they reportedly break in slower, don't seat as fast due to their higher hardness/stiffness.
They should wear slower though, thus provide a longer service life.
I could be wrong though.
Someone feel free to correct me if I am!
kingOFgEEEks
11:47 PM
Tioga County, PA
Just a theory - the F-cast are carbidic cast iron, which appears grey according to this:
http://www.giessereilexikon.com/en/...-2509/?cHash=40de89ada15d3a4614cf3a44c711bf2b
"The carbon is present chemically bonded in the form of carbide, which is why the break surface of the material appears whitish instead of gray. The carbides in unalloyed types of cast iron are mostly cementite (iron carbideFe3C), with alloyed types of cast iron, the carbides that develop are chromium, niobium, molybdenum, or vanadium carbides. Depending on the composition, the metal matrix comprises ferrite, pearlite, martensite, or austenite. Figure 1 displays white carbidic cast iron, Figure 2 illustrates an impact failure of the same material."
the darker rings may be regular ductile cast iron, which is darker in color:
http://www.giessereilexikon.com/en/...lopedia/show/nodular-graphite-cast-iron-2612/
"Cast iron with nodular graphite is an iron-carbon casting material with carbon being present in form of nodular graphite particles (Figure 1). It is also referred to as ductile iron."
So maybe it's just the difference between the F-cast rings, and regular Cabers?
066 redeye
3:47 PM
Tasmania,Australia.
+1 for wilhelms post.The problem people see if the rings don't wear as quick the cylinder may.Would rather change rings than cylinder.That's why I asked for non F rings.
Cheers,Chris
11:47 PM
Those black ones look identical to the hyway rings. I put a set in a 024 super a while back. Holds 170 psi, they seem like good rings so far. Someone probably messed up packaging is my guess.
066 redeye
3:47 PM
Tasmania,Australia.
IMG_20170810_105606.jpg IMG_20170810_105656.jpg Has anyone been able to find out how to tell difference between F and non F?Or are they all F rings now?I got mine in Australia and specified non F which they told me they was but not sure I got what
Whiskers
10:47 PM
Iowa
I just got an oem 52mm stihl piston kit and the rings are black, piston is mahle.
