difference between early and late serial stihl 024 spur /rim set up
11:32 AM
That's about what my dealer said as well. I think the rim sprocket comes with the 7 pin rim, washer and eclip.
stihl saws
You can always justify another saw.
11:32 AM
Virginia
yep i need the skinny one
checked the dealer today i can get the rim set up for 35.00
the spur is NLA in .325
The rim is a much better set up. I've never liked spur sprockets on anything. It's much easier to change a rim for different gearing or wear.
11:32 AM
Has anyone tried either the Oregon brand or Stens brand rim sprockets?
11:32 AM
Ok. Thanks Dallas.
And Stihl Saws
I bought a whole setup for the adjustable oiler if anyone is interested. Brand new Stihl. Doesn't fit my fixed oiler 026.
stihl saws
11:32 AM
Virginia
Ok. Thanks Dallas.
And Stihl Saws
I could use it. PM me a price.
stihl_head1982
Here long time
11:32 AM
USA
Ok. Thanks Dallas.
And Stihl Saws
Are you offering to trade or sell?
11:32 AM
I sold it to Stihl Saws.
jake wells
no longer here
10:32 AM
ky
my pre owned sprocket should be here sometime today i just need to do a little digging to find that stihl rim i got laying somewhere.
11:32 AM
Ok. Thanks Dallas.
And Stihl Saws
It woulda fit Jeff. It fits them all. There is more than just the pump/gear/rim, there's also a crank bushing and washer that's needed.
I have 2 setups here. The non adjustable oiler works better and puts out more oil than the PRO setup. The standard oiler is nice on a ported saw. If you need to use a longer bar in a pinch, you can let it idle a bit and blip it to oil the big bar. The pro wont do it.
I used to be quite wrapped up in the entire pro oiler setup till I realized the standard was fine for the job.
This one has the standard oiler. Slow, but did the job.
11:32 AM
OK. Good. TY
I like the fixed oiler better myself.
jake wells
no longer here
10:32 AM
ky
i got access to 3/8 picco 7 tooth rims i plan to switch the 024 over to lo pro chain.
should help it cut faster.
11:32 AM
Cool Jake. But how does that lo pro chain cut for a worksaw?
You just building a speedster saw? A cant saw?
jake wells
no longer here
10:32 AM
ky
works fine for a work saw i would rather have a 024,026 set up with lo pro.
11:32 AM
Not bad. Not sure why a tree guy would be using an 025 with a 24" bar while up in a bucket, but not bad.
