Cutting squish band
12:46 AM
If you’re asking about an 026, you can scrape the factory band out on an angel to match the piston contour, then add varying grits of sandpaper to a piston dome to match it. Or you can cut the dome off the piston and machine the chamber flat.
Here’s a sanded band.
7456BB63-399C-436F-A456-831AB5BC7167.jpeg 3B7FC284-78F3-47A1-B32A-6F95E43C683B.jpeg C9F16201-187E-4473-B87D-7BE2235ED12A.jpeg DFFD27AE-469D-4F1B-9BF9-4DA43E4365FD.jpeg FD36E315-AE79-433C-86C1-A403817F6D18.jpeg
12:46 AM
Would any one be able to snap a pic of their mandrel for cutting by hand? I’ve got a good idea of how to secure the HSS but would like to see if I’m on the right track. Thanks.
Got em at home. I use a allen set screw put in on the load side of the cutter, so the the force pushes the cutter back against the slot in the mandrel and not the set screw.
Just mill a 1/4" slot tilted back 3*
Master Bud II
9:46 PM
Northern Ca.
12:46 AM
It's all theory and a bit of experimental tinkering .I've never cut the band but if I did I'd just use a boring bar .
A pop up contrary to popular thinking does not increase the compression ,that is done by cutting the cylinder base .What two things they do is propagate the flame front and help sweep the area above the intake port .
You can increase the effectiveness with sweeps on the upper transfers or finger ports .What ever floats your boat ,they both work .On the other hand I've seen some hot runners with just a flat top piston .
12:46 AM
A welded pop up would work providing you knew the actual alloy used .It's not pure aluminum and I might guess contains silicon and nickle . I'm reminded of the movie "the worlds fastest Indian "When good old Burt used two Chevy and one Lincoln piston for his home cast pistons .Must have worked,the worlds record might still have not been broken .Flying mile ,205 MPH.
