merc_man
merc_man
- 4:51 AM
- Feb 24, 2016
- southern ontario
I am gonna be making a homemade smoker and looking for some safety tips for cutting propane tanks open.
so i have had this tank for just shy of 2 years. Day i got it i popped the cap out so it could air out. Last weekend i filled and and drained it with water to rince it out. So my next step is to cut into it...
So do i fill again with water then cut while full?
Or i also read that you can use exhaust fron an engine to purge any left over gas out as well while cutting.
So for cutting i would prefer to use the plasma cutter but maybe not a good idea if water was inside unless using tje eshaust method.
Can also use a grinder if the water way is safer.
Thanks for any advice.
