MG porting
- 11:29 PM
- Jun 28, 2018
- Wa
You're such a hater.Nope. The over seas producer couldn't keep quality with in spec.
Plus ported saw are a dumb fad.
Well if the “dealers” would quite selling their addictions, us “users” wouldn’t have an issue!The porting of hand held power equipment is cray cray. Y'all need to seek help.
Are the transfers cross section and ring off death getting any better now?
Cool.No ring of death, transfer tunnels looked good and I didn't have to take a lot out of them. Exhaust wasn't terribly high, around 167 duration. 0.020" out of the squish brought the exhaust down to where I wanted without getting the intake too long, still 0.055" from free porting and has plenty of compression. The only complain I had with the stock ports is the transfers open intake side first by 0.060", which is 6 deg opening.
Is your 066 cross cylinder and piston still on the saw mike if so have you put much time on it and how’s it holding up ?One of the things I liked most about the Cross 660 kits is the piston was lighter than OEM and had wider skirts. This is VERY UNUSUAL! I have not had any problems running the piston and rings that come with the kit (with most kits it is advisable to run Caber rings).
The bottom of the Exhaust Port (the one you can't see) almost always needs chamfering or you will hang a ring.
I have also seen bore alignment problems reported, but I myself did not encounter that problem.
I can hear the tune, steppenwolf!Damn the pusher man !!!
