computeruser
Do these kits still exist to be purchased?
I don't think they are still being produced but there are still some floating around. Im running one on my 066 that had a little more work done on it. Its a killer running saw!Do these kits still exist to be purchased?
He has plans for it and it might already be installed! I know where another is but its saved for a rainy day!@exSW has a brand new one. I don't know if he will part with it or not?? Best to message him.
It's in use now. Nearly.He has plans for it and it might already be installed! I know where another is but its saved for a rainy day!
About time slacker!It's in use now. Nearly.
Check all the ports if you get one!Check the exhaust port chamfer if you get one.
I second the motion...Should we take a vote on whether Monkey man needs to team up wif someone else to produce some gooder cylinders?
Maybe The Duke?
Maybe The Duke?
Are the transfers cross section and ring off death getting any better now?I recently ported a Holzfforma G660 and the timing numbers were not terrible, pretty easy to straighten out.
so you use a pillow in the middle so your bibs stay up ?I'd rather see someone else do it. I'm stretched as thin as I can get.
