Brewz
- 7:39 PM
- Jan 16, 2016
- Hunter Valley - Australia
Hi folks
My 084 kit turned up today
I am neither excited or disappointed. Just kinda......... Meh
Firstly I will say that the quality is very good. It woult work perfectly as a mildly ported bolt on option if your toasted your 084 and would work well.
Its fits and bolts on with no issues at all.
I have a nice OEM top end to compare it too so I will list some specs and pics below
Port timing (no gasket)
OEM: 97.5/120/70
CP: 96.5/124/5/74
Transfers were measured with a piston ring
The OEM uppers open at the intake side first by a smidge and are even both sides.
The CP uppers open at 124 on one side and 125 on the other side and open at the exhaust side a bit before the intake side which is not preferred, but not the end of the world.
CP lowers are more open towards the cylinder base but the uppers look smaller and les open towards the intake side compared to the OEM cylinder.
CP intake is lower and appears to be slightly wider and squared. More open on average.
CP Exhaust is higher which is heartbreaking (100 would have been nice) but is wider and nicely shaped.
CP cylinder looks to have its band chrome plated which will make things fun for porting.
CP piston looks really nice but has much smaller windows. I have not weighed them yet.
For my 084 build I want to port for performance so I will be using the OEM piston and cylinder as it has better numbers and I can grind it to the same of better than the CP cylinder.
If I had a toasted 084 needing a top end, I would have no hesitation in just bolting one of these on as I recon it will run great as is.
I will be keeping my cross performance kit as a spare or for when I get a 90* grinder so I can do justice to the uppers.
The OEM jug will be mildly ported and lowered to get the exhaust down around 99*
OEM: 97.5/120/70
CP: 96.5/124/5/74
