- 12:49 AM
- Aug 3, 2024
- Oregon
So the question is could you use moto seal on the outside race of a bearing as you install the bearing into the case? As a means of "lubricant".plus seal any possible scratches along the way. I've noticed when I install a crank seal with moto seal on it it slides in easier. Or would moto seal cause the bearing to spin? I'm trying to venture away from using heat because of my own anxiety. Even though I keep a temp gun in hand when I heat up a case I'm still always fearful of damaging the bearing pocket. But I I'm curious if theres a way to aid seating the bearing.
