Compression testing
tree monkey
6:58 AM
wi
friction from to tight of a grip
7:58 AM
Parasitic drag.
There's gonna be a breaking point when you're expending more energy to compress mix than you're getting back out of the compressed charge power potential.
I think it works on all engines, but some better than others, and there's a point you fall off the curve.
Also has a lot to do with air flow. How much compression you REALLY have at rpm is debatable. I would be nice to be able to measure dynamic compression.
This is where port geometry intrigues me. You leave a nice sharp acute exhaust roof when you raise it (after cutting the band) and you will get more dynamic compression than a flatter curve.
And then, compression=heat, so you're getting a less dense air charge then a cooler motor.
So it's all balance, I think.
Deets066
AKA Deetsey
7:58 AM
Parasitic drag.
I agree completely, and I'm sure that balance is goin to be different for each engine. But the question is how does one find that balance
7:58 AM
I think it's gonna be trial and error unfortunately.
I used to want super high compression and did all I could to attain it. Now I'm finding my self thinking of ways to keep it down after mods.
I still think it makes power up to around 240psi. Less on bigger saws that can't cool as well.
No doubt that it's the measure of a tight saw that one can see on the Internet. Side by side, a ported saw with 220psi will create more interest than one with 180. Just how it is in this "bigger is better" world we live in.
