Eccentric
Yes, we do have trees in Wyoming.
- 8:47 AM
- Dec 24, 2015
- Northwestern Wyoming
By hard body are you meaning like a rubber mount saw with hard AV's, or worse?
One more post. I can say the spring kit
A. It isn't a minor improvement, it's way better.
B. Doesn't turn the saw into a hard body. Which was something I was on edge about worrying.
I didn't have anything to fell with this short time but I did have some pine to buck. The saw no longer has a fine line between stall and run. I got to try it with the 20" 28" and 36" and I now wish I did it sooner. Maybe the 3 points on the 500 wouldn't have been a turn off. (Still not taking them off the 660)
Earlier someone mentioned they thought the buffers, and springs in the kit were off a 661. Anyone that can confirm that? It looks like WCS jacked the price up to $50. I thought it was only $15-20 a short while ago![]()
View attachment 287582 661 foam and spring on left...WCS 500i foam and spring on right.
Yeah, a little lube is good. Bar oil works too, lol. Oh boy...I can already hear the jokes.Did it with alittle WD40 I probably should have uploaded it last night.
Pretty easy to put them in. I’ve done it a few times already now, and have even installed it down in the strip for someone else.
I believe they were custom designed between WCS and @mortalitoolThose might be a Stihl part too, actually. I'm looking at the IPL for the 500i, 462. If I'm oriented correctly I think the 661 p/ns are 1133 791 5900, 1138 791 5903
Looks like the stock 500i p/n are 1141 791 5902
462 p/n 1133 791 5900
I'll try to find 661cm IPL to compare to.
I got that backwards. 661 on the right. Needless to say, those parts are the same.View attachment 287582 661 foam and spring on left...WCS 500i foam and spring on right.
Is Don Elmer making exhaust for saws now ?![]()
More 500i with a 32. Most of the trees are about this size on this strip. Some smaller, and some bigger. But on average, a 32 either barely sweeps, or not quite. I’m taking one or two 35’ logs off of these to make things a little easier to handle, as these are getting yarded to a paved road.
