Maintenance Chief
- 1:28 PM
- Jan 4, 2020
- South Carolina
I'm not sure, it could be?Isn't that Duracut the same as DPX?
You need a PS-7910/EA7900!All ready, will see what my wimpy little 395 does
I only have semi for the 30” and 42”, other saws will be stuck with full chisel.
posted this in the thread for this saw before. You can hear the chatter when I dog and nose down. Doesn’t do it on the rear end of the bar. Maybe chain could have been tighter too.
Gah! I just passed one on, haha. It seems to me my 6100 is heavy for class and looking at specs the 80ccs are light for class, would you agree?You need a PS-7910/EA7900!![]()
Burying that bar with an aggressive chain might be causing chatter at the sprocket nose. Try cutting a smaller piece.
Hard stuff there!
I’d say the 6100 is maybe a little heavier than other 60cc saws, but not really that much. It does hold a lot of fluids, though. Different chassis than the 64-73-79cc saws.Gah! I just passed one on, haha. It seems to me my 6100 is heavy for class and looking at specs the 80ccs are light for class, would you agree?
Darn tootin'. Duh on me!
If You have to deal with stuff like that eucalyptus there really is no replacement for displacement and comparing weights within a half lbs or so is just splitting hairs.I’d say the 6100 is maybe a little heavier than other 60cc saws, but not really that much. It does hold a lot of fluids, though. Different chassis than the 64-73-79cc saws.
The 6400/6421 is heavy for its displacement, but the 7900/7910 is not. Same saw, just different cylinder and piston.
If you like these type of saws get your self an 85cc one for that rock hard chit. Keep your 395 for stumps and milling.It would appear that I should have kept and built the 7910. But I will keep my 395 and build the 2166.
The 6100 with 20” steel bar is 1lb lighter than the 2166 with 28” LW bar.
