- 12:34 AM
- Dec 30, 2015
- Centre County
Very organized. Let me know if you need any chaos. I have plenty on my bench!
Yes. Dam wheel cost twice as much as the grinder because I thought that was a good idea at the time.Nice.
Dynasaw ABN wheel?
Philbert
I tried a number of things to make my grinder(s) portable, for field use. This is the Oregon stand:My grinder station is on wheels but still takes up several square feet of floor no matter where it sits.
The BLK is a nice nice to have in collectionThanks Duane, I have plenty of chaos, I just don't post pics of it!
I have scratcher chain on a BLK, but that is the only example I have, and Holtec is in the USA but the chain is sold direct to them, not through the dealer network.
Sorry, I got busy on another project and forgot to check.
So you are correct, on the zero scale it is not square with the sliding plate the swivel rest sits on.
So I adjusted the head until it was square and here is the reading on the scale:
So it looks like about 3 degrees off.
Well you are right. The old USG I have, made in the 70's, is true at the zero setting.
As far as the casting goes I don't see a lot of difference but there is a part number cast into this piece and not on the newer two USG's I have.
I have to ask, what is the roll of Stihl chain with the old saw tooth logo? Any chance of a close up pic of it?Squish, that looks great. You do what works for your situation, and being able to store the grinder away when not needed saves room. My grinder station is on wheels but still takes up several square feet of floor no matter where it sits.
Is the Oregon rold next to it 59AC?
I'm not sure I've seen a vice used to hold another vice before. That's definitely worth a few extra points!The sharpening Tower of Power (TM) has been further improved to now facilitate square filing. This optional extra has increased the total cost by $4.78
Thanks to this advanced technology (cheapest vice in the store) it can now be adapted to suit the needs of the square chain enthusiasts.
Or in other words, I put a cheap small vice on it so I can see what I'm doing and it holds the chains still. It's much easier when the chain is up at eye level and doesn't move.
