chipper1
- 10:30 AM
- Jun 25, 2016
- Grand Rapids Mi
Looks like an Oregon vanguard 3/8 chain on a .325 bar.
Yes. It measures chain pitch and gauge. It will also measure the gauge of the bar. It won't help on pitch of chain sprocket or bar nose pitch but that info is usually stamped on bar. The chain sprocket usually stamped as well.Ok, so would one of those plastic guides Philbert posted above tell me the pitch of both chain and bar? Like the Oregon one above....would it work to check any bar or chain? Or do I have to get the different brands?
This chain seemed to fit ok but then at the end of the bar the drive links don't fit the sprocket properly....Is this just because the various companies want you to exclusively buy their brand of components rather than interchanging?
You probably use your saws more than 3 Browns from looks of his barLights are starting to come on in this dark house....thanks for taking the time to school me....
Appreciate the bar pic 3browns...I'm going to look for those ID #'s on my bars (after I scrape away all the grime)....
I picked this up at a yard sale for a buck or two....couldn't resist....is it something worth using? It looks like it's just for the teeth but does nothing about the rakers....
Sent from my SM-G965U using Tapatalk
Thanks for the link, Philbert. Good to know these things have a use. Will give it a go...
3browns...sweet bar....seems to be a lotta hate for those vanguard chains....
These are the raker depth gauges I have....I have only used the top one. From what I read online the middle one is called a progressive style. I'm assuming the bottom one is too. Do people prefer one of these styles over the others?
I prefer the middle one at home for rakers. I keep an assortment of the bottom one in my box.Thanks for the link, Philbert. Good to know these things have a use. Will give it a go...
This is vanguard chain
Welcome.Hear ya, 3browns...I don't even know what a vanguard chain is, so...
Chipper1, good to know how that roller type is handy....and thanks for the thoughts on the gullets....
Welcome to posting Tim.How do you measure for the bow bars![]()
Sent from my SM-G975U using Tapatalk
