chain guide for newbies...
sonoransaw
2:15 AM
Arizona
That's true, Ryan. I just shot that photo of the one cutter I had sharpened, to ask how it looked. It wasn't until I was sharpening the rest that I noticed how uneven they were...
fossil
4:15 AM
Ontario, Canada
I think I found a good candidate 72 Vanguard chain that will work for the vid and test. The other ones I have are in good shape.
For whatever reason all 60 drive links had a ridge on the bottom portion of the driver heel that wouldn't let it fit in the bar groove so I filed it off (both sides, PITA).
I will sharpen it and make a quick vid of setting depth gauges. There are quite a few different length cutters with a bias to one side. The chain came off an old and well worn Homelite hard tip bar.
Now to find a saw the K095 bar will fit. I think it will fit on my Poulan 336 (54cc). I hoping to get it done by Friday as it's supposed to rain / snow Friday evening through Saturday evening.
A few busy days coming up.
fossil
4:15 AM
Ontario, Canada
Great! Looking forward to it...
I hope this is what you are looking for. My video skills are pretty shabby.
The depth gauges filing gauges I have.
Oregon gauge on the left which I rarely use. Good if all the cutters are the same length.
The middle two are Husky gauges. I prefer the flat one on the left. The combination file and depth gauge (blue) next to it works well and has decent hard steel but I find it a bit of a pain to hold.
The one on the for right is one I made for .404 chain. I made it from a putty knife blade.
You can see I flame hardened two of them to make them more durable.
The chain could be worse as far as different length cutters go. Here's a few pics typical of the chain.
A quick vid on how the use the progressive gauges. The three look different but are all used the same way.
fossil
4:15 AM
Ontario, Canada
Great pics and video! Thanks, Tim....
The chain cut straight! The chain actually cut very well. I did a vid of the XL-76 using DPX and I can't see any discernable difference.
I am certainly not that great at judging cut times though.
Here's a couple of pics of the cookies with a straight edge across the cut direction.
I would say that's about as straight as my cutting ability will allow. The fat / thin cookie is so I could square the end of the log off.
A vid of the cut. Homelite XL-76. Cuts well for a 1970's saw.
3browns
12:15 AM
Fishhook, Alaska
Excellent experiment and observations
Deererainman
Firewood Hack
4:15 AM
Union City Ky
That's sexy!
If I'm lucky the chain off this brush bar might work
Sent from my SM-G975U using Tapatalk
