ChipsFlyin
OPE Platinum Member
- 8:40 PM
- May 5, 2016
- Pittsburgh
I started that build , all together and ended up with a bad air leak in n the clutch side. All my fault. Have to pull the warm gear to put the seal on. Wtf there is an actual tool to pull that gear. Never had to do one .... Put too much heat on the gear before putting back on bent a bit and caused heat transfer to the rubber. Thought I could be quick enough. Obviously not.... Compression is good . Loosing case pressure and impulse not working. Eventually I'll do a thread.Thank you sir. That is an epic build. Will read it all!
