Case splitting using heat
Stihl working Hard
Is it Friday yet
4:26 AM
Perth Australia
I use a heat gun for splitting and a toaster oven for assembly. I use to freeze the crank but don't anymore.
I like to put the bearing in the case so it heat soaks.
so for assembley you heat the cases with the bearings in then put the crank in at room temperature is that correct
Stihl working Hard
Is it Friday yet
4:26 AM
Perth Australia
What is the downside to putting the crank in the freezer then installing it back into hot bearings in pre heated cases
Stihl working Hard
Is it Friday yet
4:26 AM
Perth Australia
It takes time to freeze the crank for minimal benefit
If it won't go on with the crank at room temp there is something wrong of your case/ bearing is not hot enough
Awesome Tony thanks up until now I used to heat the cases with the bearings in then freeze the crank for a couple of hours then assemble that's the beauty in this thread Iam continually evolving with my saw rebuilding methods thanks again awesome thread:headbang:
Brewz
6:26 AM
Hunter Valley - Australia
Yeah it's just time consuming and is not required.
I have a different 038 to put together but don't have bearings yet. Will get them leter this week
Stihl working Hard
Is it Friday yet
4:26 AM
Perth Australia
Was also wondering what you use to slide the seal over the flywheel side of the crank to stop the seal catching the groove and tearing the seal or pulling out the spring.I have always used a piece of rolled up microfish was wondering on a new technique bar using a oem seal installer
angelo c
Coal Member
4:26 PM
Celophane and 2 stroke oil
Brewz
6:26 AM
This is something I struggle with also.
Will give the cellophane and oil a go for sure
jmssaws
Banneded
3:26 PM
I heat the cases in a oven without the bearings.
Once hot I put room temperature bearings in the hot case and let the bearing soak for a few minutes then put the room temperature crank in.
I wear a pair of welding gloves and put it together with my hands,if you can't put it together with your hands you aren't getting it hot enough.
I use a toaster oven at 300 degrees for 10 min or so and there's no reason to freeze the crank.
jmssaws
Banneded
3:26 PM
90% of the time the flywheel side seal is damaged from being drove in crooked
I get several saws that people have rebuilt and couldn't get lined out so they give up and send it to me, 99.9% of the time the new flywheel seal is the problem.
If it gets just a little crooked it will bend the lip and leak. I've ruined several myself. See them that aren't set deep enough and the flywheel eats it too.
