- 8:52 AM
- Jun 7, 2023
- Norcal
I messed with one on one of my Husky saws, can't remember which brand, but yeah, use a punch the same size (or close) as the nozzle and tap it out. Do the same to tap it (or a new one) back in. Not sure if newer carbs have this option, might be just some of the older ones where you had more options to do more.I've never replaced a nozzle. Just punch the old one out and tap a new one in?
Got a carb now that's doing everything right but putting fuel in the venturi. Thinking it may have a clogged nozzle.I messed with one on one of my Husky saws, can't remember which brand, but yeah, use a punch the same size (or close) as the nozzle and tap it out. Do the same to tap it (or a new one) back in. Not sure if newer carbs have this option, might be just some of the older ones where you had more options to do more.
Very cool, I wonder what the nozzle issue was, something clogging/partially clogging or maybe erosion creating a larger opening? I wonder if a pass through an ultrasonic cleaner will restore the nozzles to new.
On the carb I'm having issue with, there was a round piece of thin transparent film floating around on that side.I think that the issue is with the check valve material inside of the nozzle. It must seal tightly at idle, and allow fuel to flow freely past it under throttle. The material is similar to what those brown colored diaphragms are made out of. It can go bad due to years of not running or exposure to ethanol.
I have seen Walbro’s black rubber check valves swell and plug the nozzle due to ethanol exposure, but I can’t recall ever having issues with the tan Mylar ones.I have an update on all of this. I ordered two new nozzle/check valve assemblies for my saws and installed them on my HD-14 and HD-16. Lo and behold, the fuel puddling issues are gone. Idle fluctuations are gone. Throttle hesitation is gone.
If you are having issues with your HD series carb, try a new nozzle.
If it isn’t working, air is pulled back to the metering chamber at idle. Thankfully, a non-primer system doesn’t need a check valve on the idle circuit. Zama trimmer carbs have too much trouble with the idle check valves, which are non-serviceable (pressed into a blind hole under the metering lever).It is absolutely necessary for that to be present and functional for the saw to idle correctly
Where did you get them?I have an update on all of this. I ordered two new nozzle/check valve assemblies for my saws and installed them on my HD-14 and HD-16. Lo and behold, the fuel puddling issues are gone. Idle fluctuations are gone. Throttle hesitation is gone.
post #43Whats the best way to change the main nozzle? Special tools?
