t4driller
Daddy Day Care
- 11:16 AM
- Feb 23, 2016
- Southwest pa
I like this method also. I just take a dremel with a sanding drum and sand the stops off. I have one carb with the plastic removed all together and it's a lot harder to get the screwdriver aligned when the saws running.I just file down the plastic tabs so you have a fully adjustable carb. Or you can tear the plastic caps off...I believe the needles do have a place for a small screwdriver. ...but they are tiny
