Cerberus
Cerberus the aardvark, not the hell-hound!!
- 12:21 AM
- Jan 20, 2020
- Florida (tampa area)
I'm curious if anybody could explain how/why Stihl made what, to my lay eyes, looks to be a VERY inefficient "crankcase to cylinder mating area", IE the match-up of the cylinder to the crankcase has this intentional "barring" of the sides of the cylinder beneath the transfers, even the metal base gaskets* have this 'side blockage' that makes it so you can't slide it over a piston.
(*these gaskets, the proud/protruding/bulging side faces downards correct? Want to say it was an OPE member's channel I was watching where they say the bump goes upwards, but the Stihl manual certainly seems to read the opposite!)
While I'm curious about why Stihl chose to make it that way, I'm also curious about "the negation of the blockage", I mean if one were so inclined to open their casing up and smooth-out that hard ridge, ditch the OEM base-gaskets, they could create FAR more "intake charge potential" for the cylinder (would, of course, need to port the transfers to realize this potential...am guessing that "hot-saw 660's" exploit the heck outta this area)
Thanks for any insight on this, oh also if you ground-off enough of your case wouldn't you "compensate" appropriately for the big-bore kits? My understanding was that their less-than-stellar performance is due to inadequate bottom-end displacement to match the larger cylinders, so if you've ground enough from that crankcase transfer area you've effectively equalized that mis-match (though I'm gonna guess that, generally speaking and 'for power', the goal would be smaller cylinder on larger crankcase, not vice versa!!)
Thanks again for any thoughts on these topics and happy holidays everyone!!!
//for fun....here's a picture of what I'll be doing "round 1 correcting" to:
///like my piston-ring compressor? ;D The handcuff zipties work a charm, not sure I'd even desire to try another type, they let you go hands-free and regular compressors do not
