Can anyone overseas get ne this part..
trooney
Admitted Woodaholic
10:21 PM
The land of pleasant living
How about a jred 625 air filter? Looks about right but I dont know about the thickness of it. I have a Cutter 670 here but its got the V stack in it.
Shane¹
10:21 PM
Kentucky
Would you mount it straight to the back of the carb vertically?
trooney
Admitted Woodaholic
10:21 PM
It looks like it might bolt on right. But I dont know the spacing between the bolts, if they are the right spacing...and how deep it is whether it will fit on the carb with enough room to clear the back of the air box
jacob j.
Only the weird
7:21 PM
Coastal Oregon
Well, an MS-210 definitely won't work.
Tom - What do you think about a Husqvarna 142 filter base and filter? The filter base is a plastic deal that bolts to the carb and then the filter bolts to that.
It looks like it would fit under your 644 cover. The main caveat would be if the carb bolts are the right spacing.
Shane¹
10:21 PM
Kentucky
I think the 625 has the same filter as the 288 I have one of those filters I can measure it for you tomorrow if you want
10:21 PM
The spacing is the same on most saw carbs from 25 cc up to 95 cc. The angle the bolts are on is the only thing to contend with.
trooney
Admitted Woodaholic
10:21 PM
I'll try to size up a 142 filter. Might work. I have less room in the left side than the right and the fuel line is right by the rt side of the carb.
If you would please
Thanks for the info Kev
SimonHS
3:21 AM
Yorkshire, England
Got a reply early this morning:
Hi,
I'm sorry, but that air filter is no longer available from Solo.
Those chain saw parts moved to Al-Ko company.
https://al-ko.com/en/
We don't have access to those parts.
Tuomas Soikkeli
Product Manager
Stokker OY
Kaarina Stokker
trooney
Admitted Woodaholic
10:21 PM
Hi,
Tuomas Soikkeli
Product Manager
Stokker OY
Kaarina Stokker
I looked for it, 13 pages to be exact, and couldnt find anything. Alot of chains and blades for the chainsaw, but no air filters unless I was looking in the wrong area?
trooney
Admitted Woodaholic
10:21 PM
And I'd really be appreciative if somebody either had a pic of the brake workings of a 644/651 or a diagram or a service manual.
Scotty Overkill
Serial Tree Killer
10:21 PM
central PA
Any chance someome in the forums has a 3D printer and could make you an adapter, or possibly you could make one yourself from a 1/4" thick piece of aluminum stock so you could bolt up something different to it? Just throwing out some ideas...
That's the bad thing about these older obsolete saws. I have several old McCulloch BP-1's here that I've been looking to adapt parts to for years now. The parts for them (namely carburetors) are almost literally needles in the haystack. Very hard to adapt anything to them without totally modifying the air filter, filter cover, and carb bix.
