Bunton 36"
Rob43
New OPE Member
6:40 AM
Ohio
IMG_0935.JPG does anyone have a picture, drawing, or anything that shows the belt diagram for the underside of a bunton 36" mower similar to the picture. I cant find a picture anywhere and my mower only goes one speed. Too fast!! Just bought it used. The guy said he just changed a bel but also said it worked fine. I dont know. I am not a fit guy and would rather not sprint behind my mower. Thanks. First time on hereView attachment 78534
5:40 AM
Your picture didn't show up can you try again?
Fish
6:40 AM
Manton Ky.
It has a variable speed pulley that gets froze up on whatever speed it sets at. The lever tightens the pulleys/belt, which is supposed to spread the variable sheaves to slow it down.
Common problem.
Rob43
New OPE Member
6:40 AM
Ohio
So its the pulley itself? I just wasn't positive if the tensioner was on the right side of the belt or what that little gear box did. Thanks for response. Hopefully picture is up
Fish
6:40 AM
Manton Ky.
My mower had a flat idler on that belt, but it was on the inner side of the belt, you pulled the lever back to slow down the walking speed. The split-sheave of the pulley is supposed to move, and reduce the running diameter of the pulley.
