- 10:04 PM
- Jan 12, 2016
- Iowa City
0.040 from the chamber. Whatever it took to set squish to 0.020" on the base.
The hard part is raising the transfers when cutting the squish that much, that's why I did it. The exhaust benefits from it because it allows you to make the exhaust at more of a downward angle from the cylinder which lessens the angle of the turn in the exhaust port.
394's are not near as bad as 395's. Raising quad ports that far takes a lot of time and uses of tiny burrs.
