Best budget Tachometer
retro
Void where inhibited
4:43 AM
UP MI
Wow, $96 for a stinkin' tach? They are all .5 second refresh nowadays, what does that tach do that the cheap ones won't, to justify its' more than twice cost?
G
Greenerpastures
Guest
Hi everyone, I got a TTO tachometer and am unsure what ppr setting
to use, pulses per revolution, on my single cyl two stroke saws.
I can chose from: .5 - 1.0 - 2 or 4 ppr.
Im guessing the saws fire / pulse once per revolution /1.0 ppr
Can anyone conirm this TTO meter will work at 1.0 ppr on a chainsw.
Thanks & Regards, john
G
Greenerpastures
Guest
1.
Pretty happy with my Oppama tach. Hoping it lasts longer than the tiny tach/fast tach I had before which failed.
Hi KiwiBro
Your tach should be a good one, made by the company
that makes them for echo Husky and Stihl, without
paying for the branding.
I only need a cheap one to initially confirm my tuning
on the limited coil saws, I will tune them by ear first,
then check with the tack.
Regards, john
KiwiBro (deleted)
4:43 AM
New Zealand
Hi KiwiBro
Regards, john
I was having trouble sneaking up on the limiter on my 7900 when tuning it. A tach helped.
retro
4:43 AM
UP MI
The TTO on my MS261 is set at 1 PPR. May depend on the motor, but its quick and easy to change that setting regardless.
G
Greenerpastures
Guest
Been using my Tach, and found 1 ppr is the correct setting for
this little TTO.
Regards, john
94BULLITT
4:43 AM
VA
I have had 3 eBay tach/ hourmeters on 2 splitters and a generator. The last one I got was around $10 and it us right on with my tiny tach.
