Beauty within the Beast- An 090AV rebirth
sledneck22
But, is the chain sharp?
9:41 PM
WI
Can’t wait for an update or another post? Nice work. Is the project complete or still in progress?
qurotro
Cookie Cutter
9:41 PM
Ar
Wow. That's some good work right there.
IEL Fan
8:41 PM
Southern Alberta Canada
The project is complete, just posting pics of the rebuild I thought people might find interesting. Just a different way to restore an old saw. I understand that this has been done more than a few times but if there was interest....I would keep posting. Same treatment was given to my early production 070. 2 piece crank and 10mm pin. That was my first big Stihl and now I have basically the beginning and end of that saw line before it ended production in North America (Not including the elusive Contra I always miss)
IEL Fan
8:41 PM
That ultrasonic sure did a number on the carbon. Let it soak in there for close to 30min. Never had piston ring grooves that clean. speaking of clean....these all went thru the cleaner. Get a load of what it did to the ground strap.
Not a lot of hardware when you think about it, for the sheer size of the saw. I always drop my bearing in a jar of rich mix. Let em' sit in there for a week or too or until they are ready to install. I throw the bearing and races in the freezer overnight. The next day I throw the case half back in the over. 250F is low enough to not change the molecular structure of the powder. The bearing and races just drop into place.
Prepping all the surfaces, getting all the holes cleaned and a tap ran thru. I lot of corners on the back side of the bar studs. That makes for some tricky and time consuming paint removal. Plus a lot of attention on the application of the powder. Make sure no spots were missed of shot too light.
Glock37
10:41 PM
Monroeville Pa
Very nice work and saw is very nice too
090s are fun too restore
Heres one I restored for Dave S
Also a 090g
qurotro
Cookie Cutter
9:41 PM
Ar
Hm.. I thought 090 should havethe Made in West Germany tag?
IEL Fan
8:41 PM
Get it all pulled together....Start bolting on the hardware.
20211111_153251.jpg 20211111_153309.jpg 20211111_160104.jpg 20211113_072126.jpg
I really like the copper oil line. I just think it is soo cool on these old saws, just adding in all the easy access bits before we get to the cylinder. Seals are in and it spins over smooooth.
Maintenance Chief
10:41 PM
South Carolina
Not to be nosy ,but it looks like you have plans for a Remington SL7A? Maybe.
Fantastic restoration of the 090.
