well back to the story.... Most of the teardown was done over skype yakking with my Dad. Not much to see there as by now we have all torn down saws and know the big greasy mess we all end up with on our bench and tools. Most of the videos were just me and Dad talking about farming, the weather and such and he was asking questions about the tear down. After I got it broken into pieces, I took more care to get more pics of specific situations.
A little side note, powder coating is a great way to paint a saw or other things. It is relatively cheap to do, no harsh chemicals or smell, the parts are fully cured once they leave the oven. The coatings are very hard and resistant to fuel and oils, and the best part....any mistakes or spills are cleaned up with a shop vac or blown clean again with a blow gun. The major downside is that the parts need to be stripped down ALL the way. Anything left must be able to withstand up to 400 deg. F for up to 20min. That means all rubbers, screens, passageways need to be cleaned and removed, that includes bearings and seals, races, oil passageways, studs, all of it needs to be broken down and cleaned. The following will give you an idea of just how intense this process is.
This was by far and away the worst part of this rebuild. The rattle can paint came off fairly easily, but the process damaged the original Stihl paint underneath. So the whole thing needed to be stripped back to bare metal. No word of a lie, I have over 60 hours into paint stripping, sandblasting and sanding to get the parts to a polished condition ready for powder. I have never run into original paint like what Stihl used on this saw. Tough does not come close to describing it. Multi layers of paint remover barely made a scratch in the layer. Sand blasting with crushed glass, bead blasting, course sand all had a limited effect. I even baked parts in the oven at close to 500F for 45min to try to harden and chip the original paint with little effect other than to darken the white to a beige tint. Once started, there was no turning back and I had to see it thru to the conclusion.
