Base gasket reuse?
Marshy
WFO Cutting
4:14 PM
Mexico NY
Does anyone reuse a base gasket? I have in the past but was wondering for the folks that still have one, would you reuse it if you had to take the cylinder off?
polkat
4:14 PM
North Wisc.
I have on some i put a thin coat of hylomar onthem hust to be sure but a lot of mine get thrown over my shoulder and never go back on.
Marshy
WFO Cutting
4:14 PM
Mexico NY
Same question but regarding exhaust/muffler gaskets..? I've gone both ways...
Marshy
WFO Cutting
4:14 PM
Mexico NY
I'll be picking up some thin solder to check squish and will likely delete the gasket anyways but just wanted to ask about reusing them... Am I asking for trouble?
Moparmyway
Its just a saw
4:14 PM
In a meeting
Depends on what saw youre thinking of removing the base gasket from. Best to check squish to be sure
SteveSS
3:14 PM
In the limited quantity of saws that I've done, the paper gaskets tear on disassembly and get replaced depending on squish with/without. On the Dolkita that I'm currently working on, the gasket is metal. As long as you don't put a crease into it, it should be golden.
mdavlee
Hillbilly grinder
4:14 PM
TN
Stihl and dolmar I reuse. Husky I don't like to use them period.
CR888
8:14 AM
Australia
I don't think any reputable dealer would reuse a cylinder base gasket. I have on my own stuff but any good tech will do their outmost to give a paying customer's saw the best chance of long the survival. That includes replacing gaskets when the head is removed. Very cheap insurance really.
Jon1212
Birch! Please.....
2:14 PM
Utah, unfortunately.....
Exactly.
gmax
7:44 AM
Australia SA
It's easy enough to make gaskets just need a knife and hole punches, .04 mm gasket paper works fine.
