Bar tip measurements
Woodslasher
Teh debil
1:30 PM
Commiefornia
This is an unusual request, but could someone with a Tsumura and a Sugihara bar take a picture of the part of the bar that is roughly 5 inches from the tip, sans chain? My 3-rivet Oregon bar bit the dust and 5 inches down from a new Oregon bar's tip puts me smack in the middle of the tip rivet, which is not a good point to drill a hole for one of my mill's mounting bolts. Finding a new 3-rivet tip will be pretty hard and the bar itself is pretty beat, so I'd rather just get a new, fresh bar that doesn't utilize obsolete parts so I'll never have to worry again.
Woodslasher
Teh debil
1:30 PM
Commiefornia
How long of a bar and what mount are you needing? I have a stack of used bars in several lengths here.
I'm running a 36 inch D009 attached to my 2100 on my mill currently. The big problem is the mounting hardware location. I don't want to give up my auxiliary handle, but keeping it means I can't utilize any of my modern Oregon bars on my mill, hence my dilemma. I've got 4 3/8 x 36 inch bars, but since they are the new Oregon's I can't use them on my mill.
jacob j.
Only the weird
1:30 PM
Coastal Oregon
Gotcha - I'll measure the Sugi and Windsor bars I have here - The Windor may not be a good choice for the same issue that you have with the Oregon single-rivet tip.
Ronie
4:30 PM
NC
Probable not the ones you need, I think they may go on them bars with a curved nose.
Woodslasher
Teh debil
1:30 PM
Commiefornia
Yes, they are banana nose tips, and yes they wouldn't work too well on a 36 inch milling bar. Also they have little flats, mine does not.
deye223
AIR FUEL SPARK VROOOOOM
6:30 AM
My sugi 32" has an aluminium plug that can be pushed out a smidgen over 5 in from the tip of the bar not allowing for the chain .
srcarr52
4:30 PM
Iowa City
It looks like you have two holes 7/8" apart. Can you move the mill arm out a bit more and shoot both holes through the Oregon bar tip between the rivet and the sprocket? There is plenty of room to fit the two holes there.
Woodslasher
Teh debil
1:30 PM
Commiefornia
Yes. Yes I believe I can, but that would make me feel really stupid for overlooking such a simple solution so I have to find a different way of solving it.
