Bar oil summer vs winter
pbillyi69
10:59 AM
USA
i doesnt get cold enough here for me to really worry too much about thick bar oil. if its that cold out i would not be out there working i it unless its an emergency. thankfully. but where it gets really cold you can do what some of the others have suggested by thinning the oil or just get some that is already thinned down. i just depends on how much time you want to spend screwing around with oil.
Philbert
Chainsaw Enthusiast
12:59 PM
East Dakota
If it’s cold enough, you don’t need bar oil, in the right applications!
* Note: I would suggest a modified 2-wheel dolly, to saw from a standing position.
And many people make a notch, and attach a large, trolling motor for movement.
Philbert
pbillyi69
10:59 AM
USA
i like it. i did a tree job one time where the only way to get the wood out was in a lake or on the barge that we had to rent from the city that the lake was in. we did a fair amount of limbing with our bars in the water. luckily it was an unusually warm winter that year because we got pretty wet every day. running the bar under water.
bwalker
1:59 PM
Montana
I thin 25% with kerosene in cold weather: this was a recommendation from Oregon (?), or in a manual from one of my saws.
I don’t like the small of diesel.
Corded electric and battery saws don’t have internal combustion to heat up the bar & chain oil. But, because they don’t contain mixed gasoline, I can safely keep them warm, indoors, or in the cab of a vehicle, until use.
I have used battery saws down to about 20°F. The same batteries are used to power ice fishing augers, etc. Just don’t charge them when frozen.
Philbert
Mineral spirits works too and is cheaper than Kero in many cases.
Jeff Lary
Do it in the woods with your Partner!
1:59 PM
Maine
Mineral Spirits, I never thought of that. I am going to get a re-fillable air pressurized sprayer for my shop. was told many people fill them with mineral spirits instead of bulk carb cleaner or brake cleaner because its cheaper.
IffykidMn
12:59 PM
Minnesota
Philbert
I am not certain but believe that the guys cutting spearing holes in the lake use vegetable oil for bar oil for pollution reasons.
Philbert
Chainsaw Enthusiast
12:59 PM
East Dakota
Probably not needed with the excessive water, I'd guess.
What I have heard is no oil, and sometimes, no depth gauges (!) for a dedicated, ‘ice only’ chain.
Philbert
Mig_Selv
7:59 PM
The Arctic Circle
In negative F, even canola oil has a viscosity index, somewhere around that of Hellmanns mayonnaise, and gets difficult to handle.
I was working in -5F yesterday, and at that temp, it's no longer simple to make oil do it's job, not damage the pump, and generally just be able to pour it in the tank.
Oregon bar oil, simply refuses to leave the jug at that temperature.
I give the canola oil 10% isopropyl alcohol. It doesn't stink, is relatively harmless to its surroundings and does the job.
This is good down to -20F. At that low temps, it can't catch fire.
IffykidMn
12:59 PM
Minnesota
Being able to work and earn money might not be an emergency but was considered rather important :sisi1 , many a morning we started out at -20/30f and never used anything but summer blend squeezed out of the jug or prewarmed under the trucks floor heater.🥴
IffykidMn
12:59 PM
Minnesota
I still have a couple of my 10mm 044s with heated handles that I ran back in the mid 1980s and they still have their original oil pumps in working condition.
Mig_Selv
7:59 PM
The Arctic Circle
Won't that kill oil pumps if done on regular basis?
Or was it something you did, once in a blue moon?
Here it's around -15F a large part of the year, hence the canola oil / isoprpyl mix, based on the assumption that oil too thick to get out of the fueler, won't do much better in the saw, but it's nothing I can claim to have tested long term.
Loony661
462’s 4-LIFE
12:59 PM
Winona County, MN
Dedicated B&C oil is a hoax/scam for the masses to milk $$$ off.
Nuff said!
Suit Yourself!
You’re a broken record. Bar and chain oil is cheaper here than canola, and cheaper than hydraulic fluid.
I understand it’s not that way where you are, but for a lot of us, bar and chain oil is the less expensive option. So yes, I’ll continue to buy it and talk about it here with peers.
“You’re barking up the wrong tree” as we say around here, when you try and tell us that they are scamming us.
