Anyone run 100LL A gas in a 4-mix?
av8or3
11:37 PM
Waleska,Ga.
Torco is the product I used. But back in 2004 it cost a lot less. I could buy 5 gals for what you’d have to pay for 64 oz. now.
av8or3
11:37 PM
Waleska,Ga.
Lee H
8:37 PM
cape cod ma.
I have been using 100LL in my saws and all my outdoor power equipment for over 20 years. Weather it's a 2 stroke or 4 stroke i have never had any issues at all. Never fouled a plug and i see no drop in horsepower. The shelf life and lack of ethanol are the 2 primary reasons why i use 100LL and will continue to use it.
Eager Beaver
Active OPE Member
11:37 PM
Athens TN
I agree Lee. I have used it for about 20 years. Shelf life, 100 octane and I have no issues with it. Sometimes I mix it with 87 non ethanol.
bwalker
11:37 PM
Montana
Here’s something on Tolulene.
I just happened to think. Coats your exhaust reddish brown.
Thats MMT that makes your exhaust reddish brown.
Lead while make it white colored and your plug while sometimes take on a weird yellowish hue.
Toluene, which avgas has a heavy dose BTW doesnt do any of that stuff. It does provide for poor throttle response in a two stroke and if the fuel has too much of it will make less HP.
bwalker
11:37 PM
Montana
My question: Why would anybody want to use AV gas in their 2-stroke equipment?
Good question. Avgas will make less power than pump fuel in a normal two stroke. If you run it you will also be breathing in lead and bromine compounds. Its only advantage is it stores for a long time. I would just use canned alkylate fuel.
EFSM
10:37 PM
Extreme southern IL
Maybe now would be a good time to remind everyone that octane does not mean power. It’s simply a metric of resistance to detonation. If you’re running a saw with 250 pounds of compression, then you may need 100 octane.
Am I explaining that right, @bwalker ?
bwalker
11:37 PM
Montana
Yep, spot on.
blacksmith
11:37 PM
central PA
I as well have run it in my saws for years and have never ever had one issue.
I get it from my Stihl dealer and he told me that it was devolved by the US Navy in 1913 and is still the same formula. He told me that it actually runs cooler than regular gas. He also told me that it has an infinite shelf life.
I have NEVER put any kind of Stabil in it and my stuff always starts and the carbs never have had any issues.
The only additive that I mix in with the gas is Marvel Mystery Oil along with my 2 strike oil if I am mixing it for ny saws.
I did a complete rebuild on an 066 that I had. Ran it for quite a while and was curious as to what everything looked like after a lot of run time and this is what it looked like.
ammoaddict
11:37 PM
Granite Falls, NC
A stihl dealer sells aviation fuel?
bwalker
11:37 PM
Montana
100LL was not developed for the Navy in 1913...
It does store for a long time, although not infinitely.
It also exposes you to the inhalation of lead and bromine compounds. Yea, no thanks, not in handheld equipment.
Busa2r
11:37 PM
florida
There are more fairy tales and old wife stories about av/gas than stories about Sasquatch. If you are over 55 and can remember, We ran Sunoco 240 &260 and other brands for millions of miles on cars that had a lot more lead than current Av/gas and there were no 3 eyed children born. It will affect some types of plastic or vinyl lines usually making them swell and mushy. Only other ill effect is 2 strokes will start easier regardless of temp.
Often more likely a clogged air filter.
bwalker
11:37 PM
Montana
After lead motor gas was banned IT'S went up significantly. Running handheld equipment on leaded fuel just isnt smart.
