awol
- 5:56 PM
- Jan 4, 2016
- Cabool, MO.
I'm righ here!
This is the first page of notes, there's a couple more; I hope it's readable! I have this saw complete, but couldn't leave it alone; last couple of evenings have been spent experimenting with another version. I also have port widths recorded and will post when able to.
Yes, the cc denotes case compression in degrees; as a general rule, the slower the desired operating speed, the more cc is needed. My little P5000 runs ok on 19 degrees.
Stock port widths: EX 1.010; IN .949; pri. trans .404; sec. trans .511
Ported widths: Ex 1.109; IN 1.000; pri. trans .505; sec. trans .515
I still cut the squish band in a lathe; with jug bolted to plate, I first run the indicator up and down the bore and adjust the bolts to get jug square to base. The move up to top of bore and center it. This saw had 130psi stock and I would like to see 230, so we removed .060 from squish, and .060 from base. This also left the ex. and in. close to target.
Cutting the base and cylinder extension; I like the aluminun for a mandrel.
So case compression is degrees from intake closing to upper transfers opening
Phyxed for clarificationTransfer opening
Yes, that would be a very good thing to do! Pistons for these are almost unobtainable, but I think with enough machine work a Husky 365 Special piston could be used in the 667. That also would open up the opportunity to use fingers or auxiliaries if so desired!Going to have to dig out my 667 jug.
They are sealed by o-rings, kinda like the Husky. I dabbed a little bit of sealer on those also.What is used to seal the trans caps Alan?
