I got a chance to pull the piston off. The circlips were intact. I think the bottom ring broke somehow. Anything to look out for when I reassemble? What's the best way to get the bits of broken ring out of the crankcase?
It definitely ate something. My gut says I somehow broke a ring, because it was in pieces when I tore it down, but how? I will inspect the big end to be sure. If a needle is missing, I have my answer.
