Aluminum felling wedges
davidwyby
Rural desert logging
1:06 AM
Extreme Southeast CA
The other day I tipped a 48” back weighted oak. Gave me the opp to test wedges and their bangers. I noticed the forester hard head seemed to drive the best. @Woodpecker do you (or others) have a brand that seems better? I want to get another one or two.
@chiselbit
Woodpecker
Sassy Madam
4:06 AM
@chiselbit
I’ve had the best luck with the hard head brand plastic wedges. They are tough as nails. I broke several forester hard head knock offs. The plastic on those was super soft and the steel insert only went in like an inch. Complete garbage!
Philbert
Chainsaw Enthusiast
3:06 AM
East Dakota
Hard Head made full, ‘T’- capped wedges, and ‘Hard Head Junior’, wedges with only a steel insert, to reduce weight.
I like the idea, but they kept pulling my pants down.
Some of you guys wedge harder than me, so they can be a good choice.
Hard Head, with ‘T’-shaped cap.
Hard Head Junior, with metal inset only.
Philbert
Woodpecker
Sassy Madam
4:06 AM
Philbert
I didn’t know they made the junior version. Good share.
Typically when I’ve had the regular hard head wedges first fail that “T” part will break off. The insert in the wedge still remains and the wedges still last a long time after.
The Junior version is a good idea and very likely a great compromise for extended work in the bush because the regular hard head wedges are fairly heavy compared to regular plastic wedges.
dangerousatom
4:06 AM
Quakertown, PA, United States
I have a few home made aluminums but I only use them for gapping out 2 plastic wedges on the final push to get the tree over. Im not a fan of cutting close to them after literally snapping a tooth off my old 55 rancher.
The best wedges i have are the ones I made out of blocks of UHMWPE from the local junk/scrap yard.....God Bless Glick's and their fabricators wonder land of stuff, its mind boggling.
Swanman62
2:06 AM
NW Montana
Just to keep the thread alive. I picked up this little beauty at an estate sale the other day. It will go in my wedge pouch to try out. It might be handy to stack on top of a plastic wedge when things get a little tense. Or should I say “in a pinch”. IMG_7878.jpegIMG_7877.jpeg
davidwyby
1:06 AM
I realized a lot of My trouble with wedges popping out was geometry and species. With a small diameter tree, the distance from the back of the tree to the hinge is short, so the angle is much steeper, short wedges make it worse for the same reason.
Also the trees being desert species are hard and springy, a whack pushes the tree fwd, releases pressure on the wedge, and then it springs back and squirts the wedge out.
Philbert
Chainsaw Enthusiast
3:06 AM
East Dakota
Have you explored different types of textures / spikes / patterns to help hold them in?
Philbert
