All Things 288XP
thedude74
Bonafide & Stuff !!!
5:27 AM
Alaska
Yeah, you're missing a little over 1/2" of case there. It could be welding in but the saw would have to be stripped down.
Good to know. Is it worth repairing? By that I mean will the repaired area be as strong as the original case or will it be e weak spot that breaks in the future,?
Soak it in degreaser and pressure wash it to see what all it needs.
Yeah. Pretty much planned on a complete disassembly and rebuild. The top cover to case holes are pretty well stripped and wallowed out due to a previous owner using random screws....there probably more surprises waiting inside too. Lol
Remove the electrical first
I noticed the coil wire is routed right there as well. It's kind of an odd 2 piece coil design.
srcarr52
8:27 AM
Iowa City
It would be just as strong as the original case. The weld is stronger than the original cast, it's the blended areas that become the weak link.
You can usually heli-coil the top cover holes, if not they can be welded too.
thedude74
5:27 AM
Alaska
Ok, who’s hoarding all the spring style buffers? I’m looking for a few and they ain’t cheap new
Mine currently has the spring style buffers. Haven't torn it down yet but I'm guessing one or two may be broken. Have a set of rubber av mounts on the way.....your welcome to my old ones if you cover the ride....Maybe you have a spare flywheel side crankcase half?
Woodwackr
6:27 AM
ID
part#? I have some springs but not sure what they go to :p They are at least numbered
davidwyby
Rural desert logging
5:27 AM
Extreme Southeast CA
I bet I do.
8:27 AM
Spring ALWAYS breaks. I switched all my 288s to rubber. I have 3 288s only 4 of those spring survived. The 281 from 1989 has rubber and still good to this day.
The Spring's even oem were always too soft on the saws i have
Making for floppy bastard's
And they didn't last long under heavy use.
I've tore a few rubber buffer's but they have been far more durable and make a better handling saw to me.
davidwyby
5:27 AM
I don’t remember the recipe I settled on for my 288 but I think it was just 2 or maybe 4 springs in the back to reduce vibes.
srcarr52
8:27 AM
Iowa City
I personally run the 4 rear spring and just the large spring on the front... no rubber mounts on the bottom front of the tank.
