HELP! Aftermarket piston and cylinder with different timing?
Yellowking86
6:32 PM
Massachusetts
I have a 3120 I replaced the crankshaft, bearings, seals and put on a hyway P/C and when I put it back together it backfires and dies. I checked the flywheel key it was fine. I tried a new carb same thing. I removed the kill switch didn’t help. I tried 2 other known good ignitions. It passed vac and pressure test. I tried another flywheel that I know works. I’m stumped??? I’ve gotten it to idle a couple times and then it backfires and dies. If I wait a day and try to fire it without choking it it just backfires. Anyone have any ideas? I’m pretty new to building saws and I’m ready to throw this thing out the window.
Shane¹
6:32 PM
Kentucky
Did you use sealer on the base? Have you checked to make sure the impulse port isn't blocked.
Aftermarket crank? Is the keyway slot cut in the same spot as the original?
Yellowking86
6:32 PM
Massachusetts
No sealer on the base, I will check to see if anything got into the impulse port thanks for the suggestion.
jacob j.
Lord of Cargo Pants
3:32 PM
Coastal Oregon
Is the ignition original to that saw? The 3120 used several different flywheel/ignition combos and most are rev-limited.
You can't mix and match some of the ignitions and flywheels. It sounds like an ignition timing issue to me.
Yellowking86
6:32 PM
Massachusetts
Yellowking86
6:32 PM
Massachusetts
Just pulled the cylinder and checked the impulse it’s clear.
Yellowking86
6:32 PM
Massachusetts
It does the same thing with the coil that was on it when it was running before the crank broke.
backhoelover
I like tools
6:32 PM
lincolnton nc
Need to check your spark at no less than 6mm gap, if you can jump a 6-8mm gap the coils is putting out enough volts to firing the plug under compression. have you tried changing the plug? autozone used to sell a adjustable spark tester you can adjust the gap on for cheap, just have to be careful as its open to atmosphere.
Yellowking86
6:32 PM
Massachusetts
Yes I’ve tried a couple new spark plugs. I’ll try what you suggested.
Ketchup
Epoxy member
4:32 PM
Colorado
Outlier suggestion, but sometimes they’ll backfire if the muffler has the right amount of unburnt fuel in it. It might be flooded. I’ve had that when I put too much fuel down the throat to get a new build started.
