sonoransaw
- 9:10 PM
- Jan 7, 2020
- Arizona
Isn't it the other way around? Usually an air leak means you need to RICHEN or turn OUT the screws to allow for all the extra air from a leak. All the way in is pure LEAN. Am I mistaken?
When you say Idle screw do you mean the throttle butterfly adjustment? I am thinking you meant the Low Speed Mixture Screw. Both High and low should be between 1-2 turns out. I get the saw to idle, then rotate the low speed screw to get the highest rpm, then use the idle screw to put it at the right rpm per the service manual or where the chain stops moving (given you have a good clutch), then I set the high screw to just start four-stroking at full throttle and verify with a tach. My buddy Craig said he sets them for 11,000 to 11,500 out of the wood. The four-stroking should clear up once it starts digging in to the wood.
Thanks, Kenny, yeah I meant the throttle btrfly adjustment, not the lean screw....
Now I'm getting pissed. Came home last night, wanted to cold start the Poulan, make sure everything was ok, then get paid! NOPE! Now she has an erratic idle, up and down. She revs ok, needles are at 1-1/2 but holy crap is the idle ever erratic! The chain will stop, then spin like mad, then stop. I guess a pressure/Vac test is going to have to happen. A couple guys asked about fuel, etc. Everything from the lines to the filter to the carb to the canned fuel is NEW. I'm ready to turn it into a small boat anchor!
Did you ever get it figured out? I get frustrated fooling with my poulans, at least the one this thread is about (the 46 cc one does fine)....
