MinnWeekendCutter
- 8:22 PM
- Jan 10, 2021
- TN, run saws in MN
Day to day, you start it, give it 5-10 secs on fast idle, 20-30 on idle, then run it hard. It will tune itself and improve the tune until it is optimum. Not sure exactly the frequency, but it keeps checking high speed tune regularly when running at full throttle, and the same for idle tune when idling. It can’t check high speed tune when idling of course. Once enough samples are gathered, it adjusts the tune, then repeats the process.
They reset is if it the tune is clearly off, most likely from a long time since last run. It gives the the saw a long enough period running at full throttle to set the high speed in one jump. Cutting blocks it might take two or three times as long before enough samples are gathered due to the off throttle time between cuts.
This rings true in my (limited) experience. My two autotune saws run great overall. I start and run them as you’ve mentioned (probably not as hard as I’m out of shape and just a homeowner hack anyway). The 550xp mk2 took a bit of time to get really dialed in when I ran last in 8F weather and then started it up weeks later at 65F. I didn’t do anything special and it really came alive after maybe five cuts. In the future if I experience such extreme weather changes between run cycles I may try this “reset.” Or maybe I should think of it more a a “learning” event than a reset. Good info in this thread.
