OG-Forestry
Active OPE Member
- 3:42 AM
- Oct 6, 2024
I’m trying to find out if this is normal, or if it’s time for rings, or if I possibly have a air leak.
I have a 661cm that will barely make 100 psi of compression. Yet it pulls the 36” bar no problem and runs great It also seems to be running lean. No scoring on the piston or cylinder that I can see by looking through the exhaust port. Also the inside of the exhaust is whiteish colored and there is no carbon build up in the exhaust port.
I also pulled a compression release plug out of one of my dad’s old “hopped up” (woods ported) saws to make sure that it wasn’t the compression release. I also checked the rear head stud bolts and they were still tight. I will check the front ones tomorrow I didn’t feel like pulling the muffler tonight.
I bought it new in 2020 or 2021 it’s the mtronic version 3 I believe. Out of the box I put a max flo filter, bark box, and i fully gutted the muffler its lives with a 36” bar on it and sometimes a 42”. The saw doesn’t see many real hard days as the majority of its work load is chunking down big trees while pruning, or falling trees around houses.
