Redfin
Meh...
- 12:08 PM
- Dec 24, 2015
- Central Pa
Granted these are forged pistons that DDawg had produced and I used a wrap of vinyl on the 12mm pin to center for pic. But I do believe the comp height and skirts are oem. DD can verify.Difference in skirt length between those 2.
I need a 56mm piston with a 12mm gideon.
395 has the correct dimensions in compression height and skirt length but it's a 13mm pin.
I did use the 12mm pin on 56mm 661 and 13mm on 395 to get ur query.
661 comp height. .885”
661 skirt from bottom of pin. .480”
395 comp height. .811”
395 skirt from bottom of pin. .688”
