661 R&D
Chainsaw Jim
Con Artist LLC
2:51 AM
Springfield Oregon
You should be able to get rid of the saw loading up lean like that if you lessen the pop off with a shorter or weaker metering lever spring. Or maybe the metering lever is too high and you missed it.
jmssaws
Banneded
4:51 AM
It's the carb off my 064 and it has a shim under the spring.
When I get to the shop I'll pull the shim and see if it's strongest with a regular or mtronic carb
