661 muffler mod progression w/thermocouple
12:43 PM
From the test I have seen done it looks like the baffle removed and maybe enlarge the existing exhaust port a little (maybe not even at all)….
Also this is a stock saw so it’s not ported….i was watching redbulls videos and seems like a little back pressure seemed to do better…
He has hundreds (if not thousands) of hours doing R&D testing on the 661, but his findings mostly apply to his ported saws.
Anytime you open up a hole or add more deflector area, you’re allowing the engine to rev and make power higher in its RPM range at the cost of some forgiveness. It’s not like there’s a one size fits all muffler mod. What works best for a short bar isn’t going to be the best with a long bar. It’s all about the happy medium
Khntr85
12:43 PM
Indiana
Pretty sure the one video I watched was only a stock 661, but yes he does have many videos….
You would think that just opening the existing port a little (on any saw), would be beneficial if not only for getting some excess heat away…I have modded all my saws (modestly), and never seemed to loose anything wether using a long or short bar….
Of course if you start making huge ports and/or multiple ports you would start changing things…
Woodslasher
Teh debil
9:43 AM
Commiefornia
You would think that just opening the existing port a little (on any saw), would be beneficial if not only for getting some excess heat away…I have modded all my saws (modestly), and never seemed to loose anything whether using a long or short bar….
I had a pair of stock 395's put in my care once, one was a basically new unit that I couldn't touch and the other was a used unit I had free reign over. Being me I gutted the muff on the one and opened up the factory outlet till it was the size of the deflector. Out of the wood sitting on the ground when I blipped the throttle on the stock one it took 1-2 seconds to get to top speed, the modded one was almost instantaneous. It was barely noticeable in the wood, but the stock one had a wee bit more grunt. The modified one was obviously quicker off the line, though.
It was kinda interesting having two basically identical units to compare because I'd have never noticed the difference with just a before and after run. I've opened up all the outlets on all my other saws (except saws I got pre-modded) and I never noticed the speed vs torque difference. I'd always felt them get quicker without realizing that anything else had changed.
tl;dr, unless you have 2 saws to compare, you probably won't feel all the differences.
Khntr85
12:43 PM
Indiana
Ya makes ya wonder about having some back pressure…
bwalker
12:43 PM
Montana
I didnt have time to respond yesterday in depth so Im doing it now.
A muffler outlet is like any other port. The bigger you make it the less it flows at low rpm and the more it flows it high rpm. Torque is a measure of cylinder filling efficiency, so its no stretch to see why a smaller muffler outlet is more forgiving than a larger one. The trick is to find the right balance that meets your needs just as it is with the transfers, intake and exhaust ports.
legdelimber
12:43 PM
N.C.
Take gawk at the exhaust on those longtail boats even the two cylinder ones would have them. About 2:20 we get a fairly good view of the motor and exhaust
Couldn't find many of the older vids now, but the two cylinders ones were just scary fast. 2:10 in this vid
bwalker
12:43 PM
Montana
Those style exhaust have a one way pulse vs a two way pulse for a tuned pipe. IE a tuned pipe provides for negative pressure to scavenge the cylinder and then positive pressure to ram fresh charge back into the cylinder. The pipes pictured just provide for negative pressure to scavenge the cylinder.
Khntr85
12:43 PM
Indiana
Yea that’s where haveing 2 of the same saws and multiple exhaust to play with would be nice….like the things redbull does which are awesome!!!
Khntr85
12:43 PM
Indiana
Well put…
