661 coils
Cigmaker
8:52 PM
va
I tired the stock filter on my 661 one cut threw it away and swapped in the maxflow. I really don't understand how we go backwards in design now days.
jmssaws
Banneded
7:52 PM
The filter setup is terrible but I rarely see one wore out from dust,almost never really.
A 395 has a good filter setup but if you take it and the stihl apart after the same amount of time you won't see any difference. Wood dust isn't like a concrete saw,I've only seen a handful of saws with the plating worn off around the intake.
Moparmyway
Its just a saw
8:52 PM
In a meeting
I'd like the nice fitted black cover, I could put a maxflo on with no cover. 461 is my falling saw though, it's nice to have a cover so the thorns and branches don't tear up the element
The best part of running the Max Flow cover, thats so far has been unspoken, is how the Max Flow cover actually keeps the filter cleaner; longer than if you used the stock cover (however its modified) and it also keeps it cleaner much longer than running a bare filter
Redbull661
661 hoarder (BlueBallz)
7:52 PM
MN
tree monkey 661 mtronic - 13,680 tach - 36" 7pin 404 bar n chain on it if that matters.
edit: - 4701A coil
full vid if you really want to watch the whole thing. was testing a new change yesterday.
