6 cube 066
Deets066
AKA Deetsey
11:08 PM
Any chance that plating is coming off right at the point your head extends into the cylinder?
The head drops into the cylinder about .070"
The plating is a good ways farther down than that
Stihlbro
11:08 PM
Virginia
Does your ring go past the plating at tdc? I see seversal markings around the cylinder.
Termitebuffet
Home of the corn can muffler .....
11:08 PM
Midgetville Norf Kacolacky
I understand that because you get the heat from the clutch and rim.
But in that short of time makes me wonder why
I just got that other pic to open ...curious that one side looks like something came thru the upper transfer and tried to lodge
thomas1
┌∩┐(◣_◢)┌∩┐
11:08 PM
Cristobal Colon
Is it possible that between the clearance with bore and the compressed o-ring you're not getting the heat transfer at the top of the cylinder that you do with a 1-piece cylinder?
Is the o-ring totally compressed or is it acting as an insulator?
Deets066
AKA Deetsey
11:08 PM
That's a possibility, but I couldn't imagine what that would be, I'm very anal about internals being clean when I assemble. And for sawchips to do that is unlikely right?
