Spike60
- 5:24 AM
- Feb 8, 2016
- Ulster County, NY
Only new carbs (blank), need to be programed to whatever coil is in the saw. The existing carb therefore should already be programmed for the coil. Also if replacing a coil with a different one, it's best to reprogram the carb, even though it will run without doing so. That's why a drop down menu allows for 5 or 6 coil options.
Those coils very rarely fail to a "no spark" condition, I'd double check everything again. Did you clean that saw? I don't see any sawdust in there. None in the coil bolts. Wonder if it had been out of the the saw.
Also, I'm not sure the the carb can completely kill the spark anyway. Never looked into it, but I suspect the flywheel might generate a spark regardless. Only test I can think of is to unplug the carb in a known good saw and see if it sparks.
