545 not idling.
Adamski
Plebus Splederns
12:25 AM
Essex, UK
ok so I have just bought a very very clean 2015 545. I bought it spares and repairs, I am yet to actually look at it but the seller has given me the low down that it’s got a clean piston and rings, revs up to the speed smoothly. But dies whilst trying to idle. Before I even get a chance to look at it are there any heads up ideas on where to look at. Tryna brain storm before looking it over.
Cheers guys.
7:25 PM
Eff around with the air bleed adjustment screw on the face of the carb, try 1/4 turn counterclockwise.
Adamski
Plebus Splederns
12:25 AM
Essex, UK
So the saw arrived, it does not idle as the top autotune carb wire has been ripped out of the connector. Looks like this happened after a drop. A subtle drop as I have only noticed on arrival that the flywheel case around the carb had numerous cracks around it. Apart from that the saw is fresh as.. what do I do, send it back or spend a bit on a case and cable?
I can find a new genuine case assembly and wire for £160. Is this good or can I get them cheaper? Is it worth it if all in it will have cost me £300. For a very very new saw with a rebuilt new case??
Decisions and advice??
Adamski
Plebus Splederns
12:25 AM
Essex, UK
Anyone know if part number 577 83 47-02 is a complete case assy with bearings and seals?
Cheers?
