SOLD 500 usd PHO Stihl 044 70cc pro chainsaw metal badge 12mm slant
wcorey
2:07 PM
ma usa
Everything I can see still points to an early 12mm, if it's a 10mm crank/piston then something most likely got swapped around at some point.
You can see just enough of the fw side case to confirm there's no 'notch'.
I have a slant fin 12 with the same newer style case and a lower serial number than this one, 13098xxx.
Still looks like a very nice saw either way, wish mine was anywhere near that condition...
Vancouver timber
3:37 PM
Canada
It is a 12mm for sure I corrected the post on as and thought I did on here aswell.. I guess cause I had it in my bead it was a 10mm and measured it with the clips in just kind of a quick check then it was easier to measure 10mm but when I pulled the clips and pin out it is indeed a 12mm sorry for the confusion boys. I have reassembled this saw and I needed a used cover for a different saw so I swapped out the sprocket cover on this saw for a different saw and put a brand new OEM stihl full wrap sprocket cover on this one which matched this saw quite nicely but if somebody wants the original one put back on it I can do so it just popped having the new cover but yah.
9050lx
2:07 PM
FL
Stupid question but is shipping to the states any more difficult? Perfect saw by the way.
2:07 PM
For the condition the saw is priced VG and should sell easily. If I didn't already have an 044, 2-462s and 2-Hybrids I'd be a buyer!
Looks like the saw has the "winter filter" which I think is usually lighter and may or may not be desirable for you.
Boomhower
1:07 PM
Houston, TX.
Mike I believe this seller turned put to be a turd. I came close to buying and glad I didnt.
stihl_head1982
Here long time
2:07 PM
USA
Wow, you just never know when a turd is gonna poke it’s head out, or if the grapes sails good. thanks for sharing :)
I can't speak for others but I do know when a turd sticks its head out. I can't speak for the grape sailing -- unless my cousin was popping me up side the head and grannies grape vine:D
I am glad for due warning that this may have been a bad occasion.
