Rich Fife
Sally slap my ass
- 5:12 PM
- Mar 4, 2023
- Central New York
I'm too lazy. LolMake up some crank stuffers for funsies?
I would think crank stuffers would be too much - the case volume is already reduced compared to the cylinder volume above it. The velocity coming from the carb into the case is going to be huge, to feed it up top.Make up some crank stuffers for funsies?
Nice... that looks good! ideally I would've welded in two spots per side but the clearance for the bearings is .015"... so I only went with 1 on each side.Rich, the only crank I’ve ever welded was on a solo 681. I tried to do a dip 180* apart on each lobe, just to prevent warpage. Mine was out very little also. I used 309 SS filler cause it bonds everything.
View attachment 444894View attachment 444895
In hindsight, I probably should've chamfered the pin and crank hoke a bit, then I could've welded it "properly".Nice... that looks good! ideally I would've welded in two spots per side but the clearance for the bearings is .015"... so I only went with 1 on each side.
I'm sure I could... I might... I have pre hardened 4140 that I could use.With your skills, a full circle crank would be easy for you.
Right, its grossly over matched.I agree that you wouldn’t want in this case because of case/displacement mismatch.
if I found a 45-46-47mm-ish cylinder that would bolt up, i think that would be the ticket!If you offset that pin to gain stroke, I think you’d need a smaller pin and rod end to clear the case.
I thought about that... but, I'm going to wedge thin aluminum on the backside, try to melt it in and then hit from the front in hopes I can blend... if that fails, JB weld it is.Well that sucks! You could just jbweld it this early in the build to make sure it doesn't leak?
Think the case is Mg.I thought about that... but, I'm going to wedge thin aluminum on the backside, try to melt it in and then hit from the front in hopes I can blend... if that fails, JB weld it is.
Definitely... it welded up but, I'm going to use my 460 case for the final assembly.Think the case is Mg.
