460/660/390xp/395xp hybrid?
Rich Fife
Sally slap my ass
1:04 AM
Central New York
Impressive work Rich. Thanks for the thread.
Thank you. As it sits now... and I reflect a little... I should've separated both cranks, turned the husky crank pin ends and pressed the stihl crank halves onto it... I would've been done by now. 😆
Edit:
But then it wouldn't be a stroker, it would be a long rod saw. Lol
Rich Fife
Sally slap my ass
1:04 AM
Central New York
redneckhillbilly
11:04 PM
NW MT
how many cc's do you think you will end up with?
Rich Fife
Sally slap my ass
1:04 AM
Central New York
thinking about this project... the stroker aspect IS cool but the amount of work is definitely more... had I just turned the husky pin to length and turned the ends down I could've used that with the stihl crank...
Ok, then it wouldn't be a stroker... I get it, but it would've taken up the excess room in the 660 cylinder... 🤔 maybe I should do another crank mod... and test it alongside this one. 🤷‍♂️
srcarr52
1:04 AM
Iowa City
Edit:
Was there room to make it an offset pin to get some stroke?
Rich Fife
Sally slap my ass
1:04 AM
Central New York
Never even gave that a thought... 🤔 if you offset it anymore idk if it would fit inside the case without case modification. I'm trying to avoid that to be honest. Husky has an 18mm pin where Stihl has a 16mm pin... hmmmmm
Im.getting more anxious to get home.and play around with more stuff. Lmao
Rich Fife
Sally slap my ass
1:04 AM
Central New York
The crank is dialed in and tig welded on the top of both sides...
The crank Barely touches the case... I'll open it up .030" per side...
