372xp bogging in cut
Jayo999
Active OPE Member
11:47 AM
Ireland
Hi there all
Recently built a 372xp that was laid up for mabe 3 year?
First timer here for building may i add
Where do i start
Got it all cleaned down. There was a pacme p&c in is. Badly scored so i ordered a hyway big bore for it.
Had my buddy build it for me. He works in husky dealer.. Crankcase was in bad condition so got a replacement. Done all bearings/ seals / gaskets. What it needed it got.. ended up putin new walbro carb too cos other one was f@#$ed
Ran perfect for 1 tank. On second tank it locked up☹
Piston scored. Cylinder was ok just tidied it up.
Got a pop up piston hyway. Went great for half tank then started dyin in the cut or under pressure in a cut especially on full throttle.
Started to seize b4 i switched it off..
Took apart plating on cylinder chiped
So i pressuee/ vac tested it. It failed both..
Found leak on intake booth replaced it.
Ordered a hutzl p&c put it in. It past pressure and vac. Reset carb to 1 1/2 turns on both started it runs fine. Put it in wood and its bogging and cutting out again..
Is it carb tuning? Or what? Im loosing my patience any help greaty appreciated
Thanks
Jason
jacob j.
Only the weird
3:47 AM
Coastal Oregon
It may need a carb adjustment if you guys used the new carb out-of-the box as is. They're tuned pretty lean from Walbro.
If it's one with limiter caps then you may to pull the caps with a sheet metal screw.
Is the impulse line good? Fuel line and filter good?
Gullet
5:47 AM
Arkansas
Exaust is not restricted?
Did your buddy do any porting?
Ronie
6:47 AM
NC
It could be like cuinrearview said or it could be as simple as adjusting the carb, if you left it at 1 1/2 turns out it could be to rich.
Ronie
6:47 AM
NC
Starting point for the 372 is 1 turn out, then tune it.
davidwyby
3:47 AM
Extreme Southeast CA
Post a vid on YouTube and link here
see vids on YouTube and how to tune chainsaw in wood
spray brake cleaner around the seals and other potential leak areas while idling to check for leaks
Gullet
5:47 AM
Arkansas
Evidently it passed a vacuum test according to the OP.
Gullet
5:47 AM
Arkansas
The whole description of these tests done (OP) is starting to smell fishy to me...
Who knows?
Vague @ best.
New pop up piston in a problem saw?
Jayo999
Active OPE Member
11:47 AM
Ireland
You could still have an air leak. The lack of power could also be the top end of China. They suck at a pretty high percentage.
I built a 660 farmertec after this and hav had zero issues wit it. Cuts like a dream so far
Gullet
5:47 AM
Arkansas
Ever measure squish before installing a pop up in a problem saw?
Gullet
5:47 AM
Arkansas
Your buddy do any porting on that 372?
Jayo999
Active OPE Member
11:47 AM
Ireland
No porting done. I polished any imperfections on the hutzl cylinder but no change to transfers or intake or exhaust wasnt widened
Gullet
5:47 AM
Arkansas
I would have at least widened the exaust a hair before installing hehe.
Jayo999
Active OPE Member
11:47 AM
Ireland
In time i will do some work on it. Wanted to get it running 1st. I work as a tree surgeon full time and only started doin small repairs since corona virus happend.. needed a new hobby as pubs closed in ireland haha
Gullet
5:47 AM
Arkansas
Nice saw, hope you get it running good after the pubs open back up!
