I Know Something
- 11:02 PM
- Dec 23, 2018
- Fairmont, Minnesota
I'm trying to pressure test a 371. The pro side seal needed to go. But its as also leaking from the barrel things internal gap. So I popped it out. Replaced the seal and that version with one off my 372 with the tiny o-ring. Still getting it to bubble. So I put the clutch on. Spun it down. And it helped some. Just some.
So to get this thing off, it acted as if it had sealant on it holding it on. Is that true. And would you put some on and take two? This is the first I've run into it doing this.
