346xp rebuild and porting
farminkarman
I like the red & black ones
5:40 AM
Neenah Wisconsin
This 346 or showed up in the mail today. The owner wants it warmed up and a switch to a 50cc top end. I know there are plenty of these threads, but I figured why not. First things first, I got the saw stripped down. The piston has a smear visible in the last pic…it wasn’t bad enough for the ring to stick, but it was enough to hinder compression a bit.BFDF7BAC-8588-485F-B80C-B04ECF1D65FB.jpeg32975579-2F45-4CC5-9B4D-1ED01C45AC40.jpegC6FD76BE-4CEA-4C05-8D57-F9DF8038FC71.jpegB6061531-05A8-4CCB-BC4A-D19C173A7542.jpeg
farminkarman
5:40 AM
Neenah Wisconsin
I believe this saw is a 1999 model, so I wanted to do a full rebuild on the bottom end before continuing with the fun part. This is as far as I got tonight. Tomorrow I will get the bottom end cleaned up and put back together.085D528D-F14A-4B2F-89CB-427F5FA52717.jpegB06C18BA-A920-4695-AA61-95D599551084.jpeg38A2A3B8-3071-4AC2-AA91-579AD2DDA532.jpeg
farminkarman
5:40 AM
Neenah Wisconsin
Got the bottom end cleaned up and put back together last night. I heated up the cases to around 200 degrees F and the bearing went right in. As soon as I got the bearings seated, I cooled the bearing pockets down with a damp rag.AF126213-F057-4862-B643-CA17118AF317.jpegD2F9EA86-7644-489A-BB67-A13CB2854089.jpegA6A6556E-C0A4-4CC4-99D1-DD2216278592.jpeg7F01EA74-FD91-46D6-AB1B-435C9DADEBB8.jpeg949743B9-F9DE-44ED-92AF-1CEFA6B77ACA.jpeg
farminkarman
5:40 AM
Neenah Wisconsin
I had ordered some 3mm burrs to help me get the uppers squared up better, but they got put on back order and I couldn’t wait. Still feel like my porting skills kinda suck…hopefully I learn some tricks along the way.
farminkarman
5:40 AM
Neenah Wisconsin
Sounds nasty. Good stuff.
I am happy with how it turned out. I built it for torque and it still whacks the rev limiter when you crack the throttle. I think he’s gonna love it. Also, I want to give a shout-out to @Mastermind for helping me source a carb for this thing. Also a thanks to @huskihl for sharing some pointers for the 346 platform. To everyone else who shares their learnings on this forum, I am grateful. You all are a good bunch…even @dall
farminkarman
5:40 AM
Neenah Wisconsin
Just a quick and final update on this 346xp project. I got permission from my local Stihl dealer to do some test & tune while cutting on his wood pile (semi load of red oak). Once I got the saw good & hot, I found it needed another 1/4 turn open on the high jet. Now the saw blubbers before the rev limiter when cold, but it cleans up as soon as it has a couple good cuts on it...figure this is a good spot until the saw is broken in. Compared to my first cuts in the video, the high jet is now 1/2 turn more open...really happy with how this saw pulls :D The owner wanted to try some square ground chain, so I squared up two loops of .325 chain with a "play" grind and put them in the box with the saw.
Chief Cat Herder
5:40 AM
Look for some small diamond burrs. They can be used to tighten up the corners on those small uppers without chatter.
